My pedal started going to the floor all the sudden. But if I pump it once or twice it's good. May start bleeding down again when stopped, but not always .......
And it doesn't always do it. Some times you push the pedal and it stops like it always has and holds good.
But there's no leak, system has not been opened, hasn't lost any fluid at all, so no way air could get in at the master.....
K30 hydro boost.
I know it can't be related (can it...?)
But the same day that started it also started dieing at idle occasionally.
Never know when. I'll pull to a stop 4-5 times, push clutch, idle, then take off. Next stop, push clutch, idle falls low and it will gradually stutter and die if I don't catch it.
It gets driven about an average of once a week. Usually always perfect. Then both of these on the same day
K30 hydro boost.
