Odd Engine troubles?
nau81blazer
Cincinnati, OH
Hello all,
So I was driving blazer yesterday and about 5 minutes after I started it, it started to slightly miss, and then a little worse, and then it was running pretty bad, then it was barely running. Real dark black smoke, it will start but i have to stay on the gas a bit the whole time and it still misses really bad. Odd thing is it gradually happened within 15 minutes. Anyone heard of this? I check the distributor hold down to see if it was loose and the dist. was moving around. It was tight down though. I assume a carb. problem cause of the black smoke. Any ideas of where to keep looking would be greatly appreciated. Thanks for the help guys! :D
--Adam
Black smoke means too rich, check for a bad choke. The choke plate should be wide open when the engine is warmed up to operating temps.
