I've been fighting with this for a while and can't figure out what's going on. So here's the series of events:
When I say it doesn't bleed out, I mean I'm not even getting past the point of cycling the steering with the motor off. What I've noticed most recently on the past 2 days I've messed with it is that after sitting over night the first couple of cycles of the steering I hear no air bubbles. However, as I continue to cycle air bubbles start emerging and the level in the reservoir rises a little. It's like air is being pushed into the system. It only took 5 complete steering cycles this morning for the air bubbles to appear. As I continued to bleed the rise and fall of the reservoir level was getting closer to the top of the reservoir.
Myself and a friend have thoroughly examined the system for leaks and found none. We even pressurized the reservoir with 40lbs of air which produced a leak on both of the cooler fittings. We tightened those up and they no longer leak. We didn't find any other leaks and tightening those fittings made no difference.
I do have hydroboost and I have bled it out through out this ordeal and haven't had any trouble getting it to bleed out completely.
Just to clarify what I'm doing to bleed the system; I have the tires removed with the front of the truck up on jack stands. All the lines are connected. I have been cycling the steering lock to lock with the motor off. Yesterday when a friend was helping me, we did 40 complete steering cycles at one point in addition to numerous other times through out the day. During that day we also bled the hydroboost of all air by disconnecting the ignition wire and cranking the motor 5-10sec followed by depressing the brake pedal 6 times. We repeated this until no bubbles issued from the return line.
I have tried starting the motor a couple of times and it doesn't take long - <1min - for the pump to start cavitating. It will cavitate with the truck just idling not using the steering or brakes.
I just keep thinking that air is being sucked into the system during "bleeding" but I can't find where it's coming from. I'd think the source of the air would allow fluid to leak out when it's sitting idle, but there are no signs of a leak.
I have checked and I'm getting full stroke on the ram. Although I'd think any air in the system from the ram not stroking completely would only show up once the motor is running.
I'm stumped and frustrated.
- Install PSC ram with a used steering box from a friend. Tapped end cap and sector shaft cap. Did not touch the pump or reservoir. Also kept stacked plate cooler in system. Everything worked fine on 100mi trip with trail run.
- Decide to install hi-flow pump from PSC with remote reservoir. Everything else stays the same. I begin having no success bleeding the system. Thinking maybe it's a pump issue, I switch back to my original pump with the remote reservoir; still no luck. I notice that the end cap on the gear box is moving in and out while turning the wheel. So I hypothesize this may be allowing air to suck in.
- Purchase new cap from JKW and install in my old box with the tapped sector shaft from my friend's box. Also replace stacked plate cooler with heat sink style cooler after reading that stacked plate cooler is not best option for steering systems. Re-install hi-flow pump. Still cannot get the system to bleed. Notice the new cap will also move in and out so I run a bead of RTV around it.
Still no change.
Verified with PSC.
