Odd Ques on Blower Motor
mudbog42
Florida for now
Ok my blower motor had stopped working:mad: , I thought:doah: , replaced it, but come to find out the new motor doesn't work either:thinking:
Wierd because after that changed the fan position one notch lower and on she comes. :yikes: Works on the three low positions when I put it on high it just stops.:what: So I put the old motor back in and it does the same(only works in the three low positions):thinking:
Measured the voltage at the plug where it connects to the motor and it reads 12.3 :surepal: when in the high position and drops to like 12.2 I think in the other 3 spots.:shocked:
Why isn't it blowing in the high position, I am stumped:dunno:
86 :k5: 350
high speed works through a relay on side of heater box under the hood.
Alirght I got it, it was a loose nut at the hotbox where it goes to the relay, just wiggled that wire and on she came so I tightened down the nut and everything works fine now
