89GMCK5
Okay, over the past several weeks I had noticed that after I shut it down there was some gurgling at the expansion tank. Small air bubbles. After some searching I noticed the nipple from the radiator fill neck for the hose to the expansion tank was cracked completely all the way around. Replaced the radiator, thermostat, hoses, and new hose to the expansion tank.
Also, when this was happening, coolant wasin't flowing into the expansion tank as it should. The hoses would just gain more pressure, get harder and harder, and the coolant level in the expansion tank would stay about the cold fill line level. Once I found the crack at the expansion tank nipple, that was acting as a pressure relief, and not causing the cap spring to compress and send coolant over to the expansion tank.
After replacing the radiator, hoses, thermostat, and small hose over to the expansion tank, and burping the system I fired it up.
Sitting at idle in the drive way, coolant flows as it should over to the expansion tank. Good to go?????
Not so. If I drive off after the temp gauge needle just starts to move (normal), the coolant doesn't seem to be pushing over to the expansion tank. I drove about 15 - 20 miles, stopped to check it out, and the expansion tank level is just about at the cold fill line, hoses very hard.
The cap I have is one of the safety vent style, when I relieve the pressure it pushes into the expansion tank pretty forcefully.
Temps running as normal, no overheating, 190-200 degrees, I can feel the thermostat cycling as the temp fluctuates in the drive way. No smoke, no water/coolant in oil, no leaks, not loosing coolant, it's just not expanding into the expansion tank.
Bad cap? That would be my first guess, cheap too, but same symptoms I had previously.
Think I should drop to a 14lb or 12 lb cap? Any other ideas?
P.S.> I did a search and the gurggling seemed to get the consensus that it is fairly normal.
Thanks guys.
Thanks guys.
