Ok so I finally got the speedo/odometer out. The speedo is still working, however the odometer is not. By these pictures can anyone tell me what i should be looking at or need to fix in order to get the odometer running again. Thanks
Look for any signs of those gears being stripped. It's been too long since i've had a speedo apart but you also need to look at where the white gear connects inside of where the speedo cable goes.
x2. The little white gear is where mine was slipping too. You can try adding some lube in that area and spin things by hand a bit to see if they free up.
