WA OEM Bolts and Hardware
kennyw
@squarebody.chop.shop on IG
Stevens Pass Highway, WA
I have parted out nearly 20 trucks in the last 5 years, tossing screws, bolts, brackets, spacers, etc into buckets as stuff comes apart. If you need an OEM bolt, I probably have a few extra. Recently, I have been getting better at sorting them so I can find them when needed.
$10 shipped minimum for less than 10 pieces
$25 shipped for a full small flat rate
$50 shipped for a full medium flat rate
Make specific requests with pics and dimensions preferably so it is easier for me to match up.
Any idea how many into a small or medium flat rate? My project will need tons of bolts, ie i have nothing bolted on in front of firewall. Bolts for hood, fenders, core support etc. Ive got a small stash, but will certainly need more.
A medium flat rate of random body hardware will probably be close to 20 lb. That would be close to enough for a single truck i would guess. But I have not filled one up yet. I can do one this weekend.
I also have all the little trim screws, larger body bolts, and even body mounting bolts and washers. I thought about making this ad before getting good pics of everything.
A medium box should do it for me. Let me know what it translates to, would take mix of everything, will certainly need trim screws as well (even my k5 has some mismatched trim screws i would like to correct)
Bumper Bolts and 6 longer bolts in smaller box in pic 3, 4 large washer long bolts pic 4. Small flat rate. Thanks
