Thank you!!I think I have one but I’m out of town until this coming weekend. I’ll check what I have and post up this weekend if you haven’t marked this post “found”.
Same, I don't remember seeing anything like this.I have never seen one quite like that. I should have one from an 89 Suburban though in good shape. I know I have one sitting on the top of my oil drain barrel so I will go grab a pic.
My 74 with a 454 had a different looking oneTo me, the cooler pictured looks like one from a 73-80 body style. The one I have (that looks like the one pictured) came from a Blazer w/ 400 engine, I think it was a ‘78. Fwiw, I should have the entire set up except for new filter adapter gaskets.
This is what the cooler outta my ‘90 looks like
I have had a few like this but rust belt life they dont like to live after removed . Or sacrifice the lines but have fun getting out of cooler ends still a gamble .Looking for a nice OEM engine oil cooler for an 85+ GM truck. Small block & big block are the same and what I'm looking for. Attached are pics of what I'm after, except I would like one that is in much better shape and doesn't leak! Thanks
Nope its engine oil .I think OP has posted a pic of the OEM transmission cooler on the later trucks. pretty sure that's what the one on my 90 burb looks like.
Just a little lolThey make a comb for that to fix & straighten the fins . Lisle products .
