Sold OEM gauges diesel
obijuank5
1 ton status
Solutions
Central Texas
Selling some things I have collected but not using.
Nice used mechanical cluster with clock and harness. 110 shipped.
Diesel fuel gauge used. 40 shipped.
Air pressure gauge, not sure who will be boosting 150 psi but you can. It has two needles. Originally for tank pressure and one for pump pressure. 65 shipped.
4k diesel tach. Similar treatment but focused only on tach and fuel gauge. Same price but it will come with the new speedometer. 440 shipped. Very rare cluster. Tach is tested and guaranteed working.
Sold
So I have a 90 blazer with an electronic speedo (VSS) and fuel gauge next to it. Id like to set it up with a tach like in your first picture. is that not possible with VSS speedo? is that what your implying? Do you have information on that tach and small fuel gauge like part numbers? Sorry I don't mean to hi-jack your thread but every time I look into this i get so lost.
If I purchased that cluster off you could I just put my VSS speedo in and be good? or put the tach and fuel gauge in my cluster (probably with custom wiring) and run them?
Both of those clusters sold. But I have another vss cluster to try and see what it takes to install this 4k tach in a vss cluster. I haven't done it yet. One of those things I'll get around to.
The 4k tach with fuel gauge is 25054948
Sorry I think I may have miss lead you. I'm looking for the tach with the window for the warning lights and the fuel gauge that gets moved to the lower left corner. so technically two separate gauges. Just like the first picture in the thread. Do you have the part numbers for those?
Have you looked at what LMC offers? I was thinking of trying it out but not sure. ill shoot them an email. Well whom ever gets to it first should post the info up in a thread with pictures.
I dont know how to make that work.
The printed circuit is different at that left hand lower spot. Probably needs a total rewire. It would be easier to fit the tach fuel gauge and just poke a hole for the tach housing.
Yes the 4k are diesel tachometers.
I have one left and I'm kind holding on to it in case I screw up one.
Please let me know if you decide to sell it. I am interested.
440 shipped. It's yours. Theres on for almost 600 on Ebay right now.
Mine is a tested and working tachometer. And good tach housing. Just that is pretty tough to find.
