I am looking at "lifting" my stock K10 a very marginal amount of 1.25" in the front and 1.5" in the rear. This would be done with the OEM springs on all four corners with an ORD shackle & zero rate in the front, and 1.5" block kit for the rear. More or less wondering if that will be OK with the factory shocks. I assumed its probably sagged the better part of that small amount over the years but I could be wrong.
Truck only sees very mild off-roading on the sand dunes, otherwise its a cruiser. Thanks!
