OER interior spray paint???
Eason
Registered Member
East Texas
Anyone ever tried this stuff? I couldn't find anything searching.
http://www.carpartsdiscount.com/aut...k5_blazer/interior_spray_paint.html?3594=2031
I need to paint my door panels and console and was wondering if I should give this a try or go with the SEM interior paint. The one thing that I like about the OER paint is all of the color choices so that I could hopefully come close to matching the original blue interior color on my '77. Thanks in advance
Idk about that stuff but I used the duplicolor interior on my door panels and it lasted about 6 months till it started peeling off on high use areas ( on the top and arm rests).
I guess I will give it a shot, if it doesn't work out I can always redo it.
Thanks for the info.
I used SEM on mine. Its all about the prep if you want it to last.
What Teck said. All in the prep. Gotta be spotless. Spotless like handle with rubber gloves on after you clean it spotless. Do not use acetone to clean it either. Plastic/vinyl gets soft and sticky. Trust me I learned the hard way...
I used SEM on a dash board a year ago and in the SoCal sun, no flaking off or peeling.
