So my zero rates are here and the intention is to stick them on the front leaf springs and slide that D60 forwards an inch or so. I'm trying to fit narrow 37" tall tires on a stockish suspension with minimal fender cutting. I'm stuck with the factory push-pull setup. I'm aware that I need to cut my drag link ends to account for the axle moving forward. Just have some basic questions.
How far towards the rear is the front axle in the stock location? Do I want to slide it forward an inch or an inch and a half?
Okay, so I take the drag links and cut the same amount off of them as the axle gets moved forward. Any trick to this other than putting a nut on before hand, cutting off the amount needed, and then taking the nut off?
Any other hazards or issues involved with doing this? I've seen threads on here about doing this but they mostly deal with taller or move involved front suspension setups.
Visited Traverse City once, it is very nice up there, but then again I was a tourist.... and it was summer.
