Official Project Franken Axle thread - 56k warning
ANYway, things havent moved forward very much until recently. I didnt realize i got the wrong SRW hubs until i started trying to mock everything up, mine are "slip on" style, where the drum slides onto the hub, used after 1988. they are also internally different from the ones i need. which are the "bolt on" style, where the drum is held onto the back of the hub by the wheel bolts, which were used before 1988. My axle is out of a 1984 K30 dually (dunno if thats redundant... did K30's come as SRW?)
answred this for you and gave more info also.
and yes there is factory srw k30 trucks.
Sweetk30 is Ken. As in Kenny Blankenship. "Right you are, Ken!" :bow::haha::doah::D
I miss that show. :waytogo:
Why not use weld on disc brake brackets, caddy ebrake calipers, and a factory ebrake pedal? Unless I missed something in a post:dunno:
Are you trying to do a drum in rotor ebrake?
