big blaze 18
Registered Member
can i get sum pics of zero rates instaled on your rigs. and are these thangs as simple to put on as it seems?
The bolts are for offsetting the axle. The center pins go through the zero rate and the pack holding them together. The bolt goes through the zero rate and serves the purpose of the original center pin head in locating the axle on the spring pack.
Since I have some rubbage on the rear tire at the front of the rear wheel well fender opening I have been thinking about adjusting my zero rate to off set it 1" further back and don't have the small bolts any more does anyone know what size the small bolts are that I would need to get? Lenght and diameter?
