. Besides they're going to a good home....
Under Adam's hood![]()
You just became a lil more less broke
So, what is the general consensus of the diagnosis?
Problem 1. If I am reading it right it seems the heads were not properly planed and straight, and that's what caused the head gasket failure.
Problem 2. In addition to that, the springs were not right for the cam and they tore up the valve seals.
2 seperate problems? Just curious and looking for further education.
The door tag says next deliver attempt will be tuesday. NO ****ING WAY I'M WAIT TILL THEN!
I gave some poor indian customer service lady a piece of my mind and they are turing the truck around for another delivery attempt later today
. Tomorrow's list includes:They look nice! So they did not come with guideplates and rocker studs?
Did you make sure to align the guideplates to center the rocker arms on the valve stems? And I would double check your pushrod length too, they should be fine but the different heads and valves could definitely warrant different pushrods, hopefully not, but I would at least check.
I drove by this morning, truck was outside but garage and stuff was closed up so I didn't stop in. Didn't know if you were around or in the gulf.
Heads look good on there, but then again, so did the last set.![]()
congrats, good job getting it sorted out before heading south...
Flying out in the morningNice to hear there was noticable improvement too. Cant beat that.
Good News Everyone!
It turns out to be an exhaust leak!
So I took the truck for an extended cruise today and wow I almost forgot how much fun it is to drive! It definately has some more ball now too and the timing is still off. I got a bunch of thumbs up too![]()
