Ok so I just did an oil change on my 72 k5. It has a moroso 7 qt pan. So after changing the oil filter and draining the oil, I added 7 new qts of oil. Everything looked fine, started the motor and oil pressure was good. Then I took it for a spin and returned home. Then I checked the oil again and this time its reads only to the fill line on the dip stick. Some how on the drive I lost about 2-3 qts of oil. I checked under and everything was dry, no leaks. So I let the truck sit over night and checked it again this morning. Still oil level is at the bottom line (fill). Anybody got any suggestions on what to do, or what happened?
-scott
-scott
