samsterman99
86' K5, what looks to be the stock 350, with the CCC Q-jet, california emissions and all. 170K miles, if I let it sit for 1 hour, it will blow a plume of smoke out on startup. So the valve seals are shot. I know I need to replace those. I still burn, or somehow loose 1 quart every 300-500 miles. No smoke at the exhaust any other time. THere is some smoke coming out the valve cover breather, and it will spit out oil from the breather after long highway runs, so it just soaks my air filter and my air filter housing with a few ounces of oil. I dont have a compression tester with me here at school, and I am deciding betweeen replacing the seals with the engine in the car, or just waiting to rebuild the entire thing. I dont want to have to keep worrying about running out of oil, this engine is strong and runs great besides this one problem. But it really is a problem when I want to drive 3+ hours to a trail, camp and drive back. Any ideas, any experience with just replacing the valve seals? If I can reduce this to a Qt every 1-2K miles, I will be happy. I dont really have the money or time to do a rebuild this year, so I want to make this last as long as possible.
Edit: I guess a main question I have is : can bad valve seals cause a rise in crankcase pressure, or will they just leak oil into the CC. Also how much oil consumption can really be caused by bad valve seals.
