Yeah,its better to use the right stuff,than risk a failure on the road...I have used fuel line in a pinch on a busted tranny line,or P/S return line,and had it last a long time,but if its any longer than a 6" run,it tends to harden up and eventually pop or crack,once I used ALL rubber right from the tranny to the radiator ,and didn't get 10 miles before one blew apart..the truck had a shift kit,I think that may have contributed to the failure,because "stock" trannies in other cars and trucks I had spliced with rubber hose never gave a lick of trouble..I think the operating pressure on a tranny is right at the borderline of how many PSI the fuel line can withstand,and its not rated for that high a temparature either..................................................................................................I'm still tempted to try using copper tubing on tranny cooler lines,in spite of GM saying "never use copper,aluminum or brass tubing,it wont withstand the vibration and will work harden and crack..."....OK,but what if I join it at the tranny and cooler with short peices of rubber tranny cooler hose?..I'd think that would isolate any vibrations,and I'd secure it with clamps to the body where possible............................................................................................... I trust a new copper line a lot more than rusted old steel lines that are thin as paper and ready to pop...they trust it enough to use on air brakes,(and there is thicker walled stuff sold for that purpose)...I've seen old 60's mopars with factory copper tranny cooler lines too...unless they used some copper/steel alloy,I bet its nothing "special"......................................................................................someone told me not to use copper tubing for my diesel fuel lines,that it wont hold up to diesel fuel--if thats true,why are the 35 year old copper lines going to our oil tank to furnace still intact,and look like new still??....isn't heating oil and diesel about the same difference?...I'd rather run copper than the steel original lines that are covered with barnacles,that are likely to fail any day now..
