Okay, I bit the bullet and ordered premade AN oil lines for my remote filter and oil cooler. Got all that installed and we are good to go. Got the oil temp sender wired in. I just put in a 3 pole switch and have my trans temp and oil temp switched to the same gauge. Works good and wasn't that hard really. My next little project is do I put in a relay with an automatic thermostatic switch or do I just put in a manual switch? The thermostatic switch has 2 prongs and the relay only has 4 wires so I'm not exactly sure how that is going to work. The relay has one heavy short red, one long red, one black and one brown. Short red goes to the fan, long red goes to battery, brown goes to ign or fan switch, and black goes to thermostat. So would the thermostat then get the brown and black wires from the relay? I like the idea of the whole thing being automatic but I also like having the backup idea of just being able to turn the fan on with a switch. Right now I have the secondary trans cooler and the oil cooler sandwiched on top of another with the fan on top but I don't get a whole long of air flow through the bottom cooler. So I might need to do something different there. Maybe.
Oh yeah, I fixed my trans leak by relocating my trans temp sender to the oil pan itself. Not ideal, I know, but it solved my leak. Right now, with no fan on the secondary cooler, my trans oil temp saw no more than 165 and that was with a lot of stop and go and idling in town when it was 114 outside. AC was not on since that is on the list of things to get working again. That was trans oil pan temp. Engine coolant temp was no more than 160 and that was on the bottom coolant hose. Also keep in mind, I am running a +3 qt transmission oil pan and a 7 qt engine oil pan.
Joel
norcal
Joel
norcal
