The manual says the 350 takes 5 quarts. I dropped the oil and removed the oil filter. Before adding the ne oil filter I place in almost 1 quart in to the filter. I then added 3 quarts to the engine. So a total of 4 quarts. I check my fluids and I'm above the over fill line. I should have on more quart to place in to the engine. I know the oil dipstick is original to the k5. I have not started the engine up yet.
Maybe the dipstick is reading incorrectly. The tube easily comes out from the block. I have to hold it down as I pull out the dipstick. How can I tell if I'm getting a good reading on the dipstick? Is'nt there a gasket or rubber seal that holds the dipstick in. Maybe this needs to be replaced. thoughts?
