I'd like to add an oil level sensor to a 6.2 engine. Any suggestions on what parts to use? I'm familiar with Mercedes sensor, circuit, and components, but not with anything else out there. The Mercedes one is simply a switch that opens when the level is high enough, and closes when it drops too low. This in turn drives a transistor that reverses this logic to light a bulb when the switch is open. The Mercedes sensor (switch) is very large, would like to use something smaller but I don't know anything about sensors available for other GM engines that may work and be smaller and easier to mount to the oil pan.
John
John
) there have been numerous stories about the 6.2/6.5 oil cooler lines blowing out/rubbing through, etc, causing a very rapid oil loss. Most people don't watch the pressure gauge enough, but if you had a light, or better yet an alarm, for the oil level, it would probably save numerous 6.5's . . . .
