Oil lines leaking
G.M.H
Registered Member
wpg. mb canada
The oil cooler lines on my 2006 chev 2500 with the 6.0 eng are leaking after only 80,000 km. This seems to be a recurring problem with these trucks. Does anyone make better qualiy hoses that will solve the problem permanently? Or could some be made up at a hydraulic supplier. I really hate the prospect of replacing these lines 6 times during the life of this truck, as I have gotten over 400,000 km on previous trucks. Thanks.
Are thoose hose or cooper lines??
i got some extra strenght hose on my oil cooler and special fitting for the preassure (like if its a lot of it), no problems so far, i got the type that has the poly braid exterior from a local shop
MegaTech™ II ACP Hot Oil/Air Pressure Line – SAE 100R2 Type AT
I am not sure exactly. They are partially aluminum hard line and flexible hose, much like a really long P/S hose. I have replaced them multiple times on earlier trucks.
