Depending on the year there are a few different CDR configurations.
Depending on which size truck (1/2 ton with C-code emissions intake or 3/4 ton and up with J-code non-emissions intake) there will be a different intake setup as well.
Sometimes people swap the J-code intake onto the C-code trucks to get rid of the EGR bull****. Does yours have a big EGR setup inside the intake manifold when you take the cover off of the air filter housing? If so, you have a C code intake. If not, then you have a J-code intake.
That sounds like where the CDR valve is. Is there a brass colored can looking thing right about where the leak is?
I'm betting it's either clogged/stuck and oil is getting everywhere or someone thought they'd just bypass the CDR setup and now that is leaking.
