oil on the spark plugs ???
ilikeitloud
edina, minnesota 55424
well my truck has been runnin like ass for the couple days shes burnin more oil then usual and so i decided to pull the plugs replace the cap,rotor,wire etc.. well i started pullin out spark plugs and found that a few of them had oil covering them what could be causing this??
If its not smoking all the time (white smoke from the exhust), than its probably warn valve guides. If it seems to smoke, then you probably have some bad piston rings.
Smoking at startup, valve guides. Smoking when you get up in higher RPM's, rings.
Obviously not always 100% correct, but a good guide.
If you are burning oil, don't waste money replacing plugs, scrape the crud off the electrode, and re-install them.
My worn 350 had one cylinder that liked to burn a bit of oil, the plug was always "fouled" (but never ran bad) so every oil change, I'd just pull the plugs (to make sure other cylinders didn't have problems) and clean any that were dirty.
[ QUOTE ]
[/ QUOTE ]Exact same situation on my new 406...#8 cylinder will build crud up on the plug for some reason...just clean it every once and a while. /forums/images/graemlins/waytogo.gif
