ALL-DATA calls four about 4 hours. states remove exhaust crossover,
if fitted, remover torque converter shield, and transmission braces,
if equipped. nothing about raising engine. should be piece of cake!
I did my '83 in the driveway, took about 2.5 start to finish, and I was
replacing rear main seal as well. It would have taken two, but, as I was
starting the last bolt on the pan, pleased with myself, I looked by the
left front tire, and saw the oil pump!
