On my 383 I have a melling M55HV oil pump. Stock oil pan.
I stuck mobile 1 10W-30 synthetic oil in there. I say this because I have heard mobile 1 will have slightly lower oil pressure. I get 80-100psi cold.
Once warmed up I get about 60 psi all the way up to about 3700 rpms. Then the oil pressure begins to drop to about 45 psi by the time its 4500rpm. I've read you want 10-15psi per 1000 rpm.
I was thinking of sticking 20W-50 in there to see if I can get the pressure up a little more.
