mrluhman
Since buying my 89 blazer I have had problems with the oil pressure gauge. I have had a new dealer installed GM crate 5.7 put in recently and all systems are go and humming in the new power plant, which affirms to me that its the gauge and not the engine. After I start the vehicle the oil pressure goes up, then it goes down, then it just randomly fluctuates with no rhyme or reason. It mostly stays pegged at highway speeds. Before I tear into this project where should i start. Simply get a new gauge off LMC or a junkyard, or is there a sensor I should check first. If so where is it located? Has anyone else had this problem? I know this is a noob question but I seem to have the worst luck on buying and installing parts I dont need. Thanks in advance!
