Oil pressure gauge
PHIL111260
Newbie
SOUTH CAROLINA
My oil pressure gauge does not have any wiring or sending switches on the motor. What do I need to do to get my gauge working. Basically all I have is a:doah::confused: gauge??
Is it the factory gauge? What year vehicle? If it is a factory gauge and the wiring is still behind the cluster then you need to buy a sending unit for the type of gauge and then hook up the wire. If it's an after market gauge then you'll need to buy the sending unit that matches the brand of gauge and run wiring to it. If it's an after market mechanical gauge and the cappilary tube has been cut then you'll need a new gauge.
