ACannell
I am trying to re run the oil pressure sender but am having loads (
- get it) of trouble. It is a three wire set-up with orange, gray and tan wires. I believe this is what they are:
Tan - Oil pressure gauge
Gray - ????
Orange - Fuel pump shut off relay
The diagrams say the gray is for the hot fuel module - what is this module? - ok so it appears I don't have one as it only exists in the BB OG set-ups.
Should the gray wire be spliced directly to the gray wire on the fuel pump relay then?
Where does the sender get it power from? Is it 12V or 5V?
I have deleted the ecu and am carbureted. I need to find out what to do with the orange wire as it won't be going back into the non-existing ecu.
Secondly - need to know what to do with the gray wire.
Can anyone help me sort this out? Thank you very much.
- get it) of trouble. It is a three wire set-up with orange, gray and tan wires. I believe this is what they are:Tan - Oil pressure gauge
Gray - ????
