i guess you cant post pics in this forum...... so... let me paint the picture.....
stock 1988 tbi k5 blazer.
stock wiring harness is all taped up to the firewall.
I CONNECTED THE MAIN BUS WIRE TO THE BATT/ALT/JUNC just like it would have been stock.... i did this to maintain all stock lights, fuses, ignition, and yes; fuel pump.
the stock fuel pump housing, has a late 90s high psi fuel pump installed in it now.
new stand alone wiring harness and stock PCM installed for 5.5 ls. VATS cleared. it does start and idle, and respond to throttle.... for 5 seconds...
oil PSI sensor switch has a orange (hot) and a brown (fuel pump?) wire.
the brown and orange run to the fuel relay.
connecting them, the fuel pump runs non stop.
disconnecting them, fuel pump primes and starts.
