hey all!
so i have an issue., when we bought our 1988 blazer we were told that the engine was replaced a while back. when we test drove it, the oil gauge was pegged at 60 psi which i thought was a bad sensor. i removed the sensor the other day and it appears that the sensor is for a 1991 350 with a warning light. so i figured since the cluster has a gauge they just put the wrong sensor in the back of the motor. so i put the right one for a gauge ( since this is what is in the cluster, and it is a three prong sensor needing a three prong plug) into the motor and notice that the plug coming from the wiring harness is for a warning light also ( the two prong connector vs the three prong gauge plug. ). it seems to come right out of the firewall and plug into the sensor. i could be wrong, but that is what it looks like.
is it possible they replaced the whole engine wiring harness for this 1991 motor and removed the original 1988 factory harness?
i ordered a GM three prong plug but how would i hook it up to the factory gauge? i only see two wires on the current plug in the truck. how can i utilize the factory oil pressure gauge. are there wires on the back of the gauge that i can run right to the new and correct sensor?
thanks and would like any suggestions!
john
john
