oil pressure
Hazy
CA
just put my sm465 in and friends got me to go wheel my truck a little. but i noticed when i was at angles my oil pressure would go to just about 0. my oil level is fine though... is there anything i can do like a new pan or a sump or something?
ive been talking to a racing buddie and he recomended a dry sump to me but these are pricy. he also said something about a bafled pan that keeps the oil at your pickup point.
Drop the pan and check out the oil pick up tube. Sometimes they can crack, break or just come loose. That will cause the problem you are having.
assuming nothing is broken, a baffled oil pan is the best bet, but even that will only work for a little while, i remember an episode of trucks, with the crazy horse bronco, where he lost oil pressure going down a very steep hill, and had to shut off the engine and coast down. its just something that goes with crazy angles in wheelin.
but in that episode he put a different pan onn after that oil pressure problem happened. i don't think i want to do dry sump because it does cost so much. i just don't see it for a chevy 350. maybe when an ls1 goes in.
so i need a baffled oil pan. any good brands?
moroso offers a good one, i dont know the part number off the top of my head, but i think they call it the oil control pan, added bonus, its been dyno tested and prooven to add like 25hp.
