Oil psi
Me89'Jimmy
Sykesville, MD
i have a rebuilt 350 and the oil pressure always reads about 60 psi, is that normal and if not whats the recomended amount of oil to use
More details on this are needed!! 60 psi is a tad high in my opinion but it certainly wont hurt anything. how long ago was it rebuilt? It may still be getting broke in if its not to long ago.
its got 25 grand on it so far, it idles around 45 50 but the second i get on the gas it shoots up to sixty /forums/images/graemlins/thumb.gif
Sound's like a high volume oil pump to me. Or some object is holding the pressure relief valve closed in the pump itself.
I had that problem with the 454. Installed rebuilt 454 in June, ran at 60 psi. hot, at speed, at idle it had about 40 psi hot.
Then the first cool night in October, I started it up, and blew the rubber gasket out of the top of the oil filter, twice.
Pulled pan, oil pump etc. Found a piece of maching debris, just a fleck, holding the pressure releif valve closed. /forums/images/graemlins/eek.gif
my oil pres. guage has been at 60 psi since i got it. 60 psi even when its not running /forums/images/graemlins/ignore.gif
My 88 runs 60 while driving and 30 while idiling. It has over 100K on it. My other 350, which has about 3K miles idles about 15-20 and runs about 50.
when its bouncing off the cam lobes at idle in gear I have about 30psi on the freeway about 70 it will max out at 60psi. I did put some z max in it awhile ago and it gave me 10 more psi.
rule of thumb for a motor with some pep, you want 10psi for every 1000rpms you run minimum. redline at 5000rpms, you want 50psi and soforth.
60 psi is not that bad at higher rpms. Now if you have that much psi at an idle, then I might worry a little. It should drop at an idle. Mine is at 60 psi plus when cold and while driving. After it warms up it will drop between 30 and 45 psi at an idle.
My 350 was rebuilt as well (at some point prior to me buying it)...when warm, I idle at 30psi, driving I'm around 50-55psi.
If you are using stock gauges, it *is* possible to get the wrong sender. Not sure which does what anymore, but the diesel trucks had different senders/gauges, because they had 80PSI gauges.
May not be your problem, but the wrong sender for the gauge will cause problems with the reading being inaccurate...it works, just the needle is in the wrong place. Example: A vehicle with a 60 PSI guage with a 60PSI sender, on an engine that puts out 30PSI, reads right in the middle of the gauge. If you put an 80PSI gauge in there without changing the sender, it too will be in the center, but read 40 instead of 30.
Soo, I guess if you had an 80PSI gauge with a 60PSI sender, indicated oil pressure would always show higher than actual.
[ QUOTE ]
[/ QUOTE ]
No it didn't. That's simply your imagination. Oil additives are the biggest scam in auto parts today.
I dunno, JeremyK5 put some Lucas Oil Stabilizer in his Blazer when we were on a semi-road trip and it noticeably increased the pressure. Gauges don't have imaginations.
[ QUOTE ]
Don't trust an electric gauge. Put a mechanical one on it to find out the truth.
[/ QUOTE ]
Read up on them. Electric gauges are every bit as accurate as mechanical when working correctly. Everything loses calibration over time, so judging stock gauges against new mechanical is not a valid argument. (not saying it was used as such, but used vs new doesn't mean the used one is worse when it WAS new)
Not going to say that mechanical gauges aren't used anymore, but they are certainly much rarer in almost any application I can think of.
were does an electrical guage lose calibration? the sender, guage, old wiring, all 3?
Every single component can "lose" calibration.
From my understanding/playing with these gauges, GM "tuned" them with the ceramic piece on the back of them, to make them as close as possible to correct.
But, as with anything, corrosion and age will affect readings, although I've never had a gauge that was just "wrong". Broken completely and obviously yes, but "incorrect" (compared to other gauges swapped in) no.
Electronics lose calibration over time. Here at work in the lab we have to send everything that we use, from stopwatches to thermocouples to pressure sensors over to the metrology lab for calibration. Some pieces of equipment are rated to hold their cal for a year and others are shorter. We even have to send torque wrenches to the metrology lab for calibration /forums/images/graemlins/shocked.gif
