THIS IS HOW YOU TITLE A SPECIFIC QUESTION DAMMIT. When someone tries to search for an answer, you type your best guess into the search bar. I like to use "titles only", simply cause searching the entire post is retarded. So, needless to say I've searched for the answer already and only come back with 3 pages of "hi flow or standard pump" threads. GEZZZ
Did I read the torque on the oil pump mounting bolt correct? Does 65lb ft sound right?
(ps) with a title like this, the next person SHOULD have no problem finding the answer IF THEY SEARCH! Pissy mode off
