garydan
I'm in the middle of sealing up the motor. So far I've replaced a couple freeze plugs, changed the oil pan, put in a one-piece oil pan gasket. I put in a new timing cover gasket and crankshaft oil seal, water pump gaskets. I think I'm almost "done"
Anyway... I just drained the oil pan after having new oil (cheap Pennzoil because I knew I was going to change it soon) in the truck for about 25 miles. The oil looked pretty dark with a greenish tint to it (coolant?... but I thought oil with coolant in it was chocolate brown and milky).
I guess the last job I have to do before throwing the motor out is head gaskets right?
Edit: No smoking at tailpipe. I do get black specs that fly out of the exhaust at startup only one one side of the exhaust (true duals). I think that might be a valve seal or piston ring issue.
