Oil sending unit?
badmix
West Virginia
I have a sending unit on the block near my starter. Anyone know what this sending unit does ?
84 k5 original 305cid
Unfortunately I can't see pics being a non payee. I ditched the computer and dizzy long time ago. Wonder if I can pull this sensor and plug the hole?
If it is a knock sensor it should be a blind hole, won't really need a plug.
Ok,,,thanks.,,so if I pull that sensor , is coolant gonna come pouring out ? I'm a assuming it'll use standard 1/4" or 3/8" bung to block it ?
Yes, it will dump coolant. Catch it in a bucket and pour it back in through a paint strainer. Unless I am remembering wrong, again, it should be a standard pipe plug. I like a dab of sealant on them.
is pipe plug. Could be clogged with rust, have had to poke a few to drain some older blocks.
