Iceman and Max...
Since this will be a DD, I'm not looking to get ridiculous power levels. I'm more concerned with having good torque. Knowing where the torque is in these engines, I know 350hp is a LOT of torque--way more than my 305 had, or what my 350 has now.
I probably should've thrown this out there: I'm looking for something similar in
feel to my girlfriend's Yukon XL (Suburban). Prior to the Yukon, she had a Tahoe with the 4.8L V8 and 3.23 gears. The Yukon has the bigger 5.3L and 3.73 gears. I'm VERY comfortable with its power. It's enough to get out of the way when necessary, but not too much.
Now, I know at this point, many would say, just drop in a used 5.3L and call it good, but the fuel economy isn't awesome. She averages 15-16mpg according to the onboard computer, and I'd say most of her driving is her work commute, which is primary interstate.
I do however feel that the Yukon would be inadequate if I wanted to pull anything other than a very small trailer. Yes, I know my short-wheelbase K5 isn't an ideal towing vehicle, but I'd like to have the option, and more importantly the torque to back it up.
I still think the Cummins would be overkill. Now, you're saying that the upfront cost of a Cummins conversion would be cheaper than the P400? I know the frame can be modified to handle it, but really, what do you think the long-term effects of carrying that much weight would do to the frame? Are there no bolt-in conversion parts to strengthen the frame? Grafting in 1-ton frame parts seems excessive for a DD.
What's the deal on P400 parts availability? I'm assuming that P400 parts are not as readily available over the counter at my local Napa...
Again, my goals are:
1) Better fuel economy than I'll be able to achieve with a gas engine
2) Power--when I need it
3) Durability and Reliability, Durability and Reliability, Durability and Reliability...
4) Oh yeah... Durability and Reliability.
Now I know the Cummins is durable and reliable. I don't think the P400s are old enough for anyone to say for sure, although that is one Hell of a sexy engine...
Edit: Also, keep this in mind... Axle-wise, I'll be upgrading to a 14BSF in the rear, but just a 6-lug version, and I'll be keeping the 10-bolt up front. How well could the 10-bolt cope with the weight of a Cummins bearing down on it?
