Ok door panel Qs.
b89
Registered Member
ark
im trying to get the door panel off so i can push out the huge crater out but i cant get the top free it looks like clips or something. Any help will be great.
put the window down. push in at the top while you pull up from the bottom...
Make doubly sure all the screws are out. Armrest as well. Remove the door lock knobs if the flared style.
Pull the door panel out from the bottom, making sure that all the nylon clips come free, so the ONLY piece held to the door is the window channel. While pulling outwards at the bottom, and applying upward pressure, with the other hand, I just kind of smack the lower edge of the door panel upwards with my free hand, which usually pops it free.
ok i havent tryed with the window down thacks guys.
I've always rolled the window down, and kinda pushed up, and peeled away.
I've never ruined a clip yet... but my way looks to be the wrong way, hahaha.
Nope. The wrong way is to leave the single screw towards the rear of the arm rest in place, and proceed to jerk on the door thinking the plastic clips are whats holding it, until the door panel shatters. :doah::)
no here is the wrong way. a crowbar and pull on it. i built a demolition derby car and thats how i got the door panels off
i get all the screws out except for the one in where the door handle is. always forget that for some reason but it takes a little beating to get it off sometimes.
now time for someone to say something about my last sentence :D
