Much better than bare copper!..anything is better than it was--I've been known to use wire nuts in electrical emergencies and other "jerry rigging" when I'm in a bind..
I had a '77 GMC that the previous owner put a "custom dash" in he made himself with S-W gauges & speedometer,and he did a hack job ,to power everything up he pulled the wiring harness plug out of the original dash cluster where it goes into the printed circuit ,and used brass carpet tacks shoved into the connector for the various gauges ,and just wrapped the bare wire around the tack heads,then buried it all in duct tape!..I didn't discover this till one day while plowing,I smelled wires burning..
One of the wires evidently rubbed thru against something and shorted out,not at that mess of a plug like you'd think--and it glowed red,and melted itself to the bundle of other wires,causing all kinds of back feeds and more fuse popping..
I had to take the dash right out,and rather than replace the wires that only had melted insulation, I opted instead to just separate them using a razor knife and re-wrapped them with the cloth tape you use on wounds that is waterproof for bandages (all I had at my disposal..)
I was not at home,I was plowing a parking lot and that was all the customer had--looking back that stuff held up better than most electrical tape I've used,which tends to come off and get all gooey after awhile)..it was snowing and about 20 degrees out too,and was going to get dark soon!..
I knew it was not the "right" way to fix it as the wires may have become resistors after glowing red,but everything worked OK again,it was no worse than when I got the truck,and I just used it that way for several years without a hitch..but always feared one day I'd be tooling along at 65 mph and the dash would start smoking again!..
