sdavid
Re: OK I\'m Hacked. MPG stuff.
Cheap cold air/ram air intake is if you still have the stock intake with the the plastic hose that goes to the grill by the battery tray and connects. It is held in with a piece that is a flat disc on the grill side. I cut that disc off but left the piece that had the ears on it so I could still leave it attached like stock. Now it is a 4" open hole that air gets rammed through straight to my air box.
I had to take the headlight bezel off and losen the grill and just cut it with wire snips and that was it. Heck of alot cheaper than buying one, and it all still looks stock. I have a K&N to take advantage of the extra flow. Now if I am going 60mph, I get a 60mph load of cold(out side of engine bay) air pushed into the TB. Easy enough, and seems to help.
Exhaust:
As Flowmaster series go up the quieter they get. 50 is less noise that 40 and so on. The 70 series is very quiet. Go to their website and listen to some of their sound clips for examples. Also the bigger the muffler it is the quieter it will be in most cases. I have a magnaflow on my '02 5.3L and it is the small bodied one that it 3" center/center that flows straight through. It is loud under acceleration but fairly queit at 70mph. Turbo styles will even be less noise than a chambered or straight through design. Just some food for thought.
Exhaust:
