I have recently swapped from a 305 to a 350 tbi. I changed the injectors and computer to match up with the 350 and 700r. After running it and a couple hundred miles, it idles real bad like it has an aggressive cam in it and it has a really bad skip around 1500/2000rpm's 55/60mph after running about 10 min, but when you give it full throttle it seems to have plenty of power. I have replaced the idle control sensor, map sensor, and distributer module, including swapping back to the 305 computer. It is almost like one of the injectors inst firing, but it is. I have worked on TBI a lot and it has me baffled along with every one of my friends that are mechanics. I have also checked my fuel pressure and it is in the upper 20's, and the 350 was rebuilt about 6 months ago and ran fine with a carb on it. It's a 4 bolt main. Has anyone ever run into this before?http://coloradok5.com/forums/images/smilies/dunno.gif
) or have the wrong injectors (while they look the same, there are different injectors for each engine).
the injectors are right for the engine, and Brand new from advance. I looked at them run this morn and the one on the passenger side didn't have a fog patten, it's jus shooting out a stream of gas. The driver side has a fog pattern, but dribbles gas. I didn't have time to trouble shoot past that point b/c my father believes in my tractor cranking up with the lights on and it shutting down with the lights on.
