Ok first off I changed the trans pan gasket and filter on my blazer. It has a th400. I have put 4 quarts in and there is no fluid showing on the dipstick. I checking it hot with it in park.
Problem 2 The trans dipstick itself is loose as can be. I have tried to locate where it is supposed to be secured to but no luck. The attachment to the trans itself seems to pretty loose and covered with grime.
And last but not least one of the engine oil cooler lines seems to be leaking. Is it possible for them just deteriorate? I ask Cuz the fitting at the block isnt leaking. Anyway What do I ask for when ordering a new one?
As usual thank you for all info
comes from the hose itself or maybe even right where it connects to the fitting. Is there a way to tighten that or Is it time to replace it?
