ragedracer
First, 86 CUCV M1009 - TH400/NP208. The output from the transmission/transfer case where the slip joint of the rear driveshaft goes in is leaking. I know I need to replace the seal, but I don't know what seal to get. Do I look for an output shaft seal for a TH400 or the NP208? Whats leaking out is ATF, but both the Trans and the Transfer case use ATF! #1, I want to make sure I get the correct part; #2, I want to be sure which unit I'm losing fluid from!
rr
rr
