01maroonz71
well, i put this motor in my truck about 2 months ago, and it has about 1k miles on it. at idle, it overheats like a mofo but cruising is fine. the ENTIRE cooling system is new, thremostat,radiator,waterpump,hoses, and a direct drive fan.
also, in the morning when it's cold, it fires right up no problem...but kinda backfires every once and a while on me. once it heats up, it runs like a bat out of hell, but if i shut it off when it's hot, it takes it cranking over for like 6 seconds for it to fire up.
sometimes she will diesel also, not always, but maybe every 10th time i drive it or something like that
i initially thought timing, so i hit it with my gun again, and it seems fine....BTDC with the vac advance unplugged is at 8degrees...and it maxes out (w/ vac advance hooked up) at about 32degrees.
now, could the mechanical springs in my dizzy be worn out and causing it to come in too fast/tooslow???? or could there be something wrong with my idle mixture on my edelbrock 1406??? i haven't messed with it since the swap, and think that may be it...but that wouldn't cause dieseling would it???
oh yeah, there really isnt' any "heat soak" in the fuel line....it doesn't really heat up, so i don't think that could be it.
