Ok you cad. power guys...
smartcarkiller
Registered Member
Tacoma Wa.
I have been wanting to put a Cadillac 500 in my 72 k/5 and I have been looking for one for a while now. I have found some but they needed complete overhauls, and I don't have the budget for that. I found a 472 that was rebuilt about 6 years ago and only has about 2000 miles on it but it has sat since 2005 in a 1971 sedan deville. I know its not exactly what I've been looking for but I can get it for next to nothing. Ideally I would want the 69-70 Cad. 500 but so does everybody else and they are hard to come by. I guess my questions are #1 if it really was rebuilt and done right what kind of power numbers could I realistically expect to see out of it? #2 since its been sitting for 5 years what could have happened because of it sitting? #3 Am I gonna be happy with it after everything is said and done or should I hold out and find a 500 that I want? I guess I'm getting antsy and It's looking like I'll have a space soon to be able to tear my whole truck apart and rebuild and I want to be able to put the engine in while it's tore apart. Oh to the wise and informed I thank thee.....
Apples to apples you won't notice much difference between 472 cubes and 500. Not sure exactly what all was changed from year to year with the big block caddies. Some had better heads then others and so on but you'll still have some good torque no matter the details of that particular engine.
Hard to say about the power numbers without any specifics of the rebuild. It'd all just be guessing.
As far as damage from sitting, inside or outside? Dry climate or humid? If it were me, I'd proabably pull the heads and pan and inspect things. Good chance it'll be ready for an oil system priming and some fresh fuel.
NEVER trust valve springs that have been sitting in an open position for years, THEY WILL BREAK. As long as no water has gotten into the engine the only other thing that can be a problem is the rings can freeze up in the pistons and bore and either prevent the engine from turning over OR cause the engine to smoke like a freight train.
Its been sitting outside on the side of a guys house uncovered in the rain here in Washington. I'm going over on Sat. morning to see about firing her up and listen to it for a while. I have my stethoscope and various tools for checking things while its running, should be fun, hope it doesn't rain! Should I be worried about the oiling system or just fire it up and see if it builds pressure right away? I can always dump some oil in the valve covers just in case.
One more question... It has a th400 in it already, can I use that some way for my truck or is it completely different than what I need?
It's possible to run that trans with a divorced tcase. Otherwise you'd have to swap some guts around in the transmissions to end up with a BOP turbo 400 with a 4x4 output shaft. A good trans rebuilder should be able to make the swap in pretty short order.
I wouldn't just try to start it without some prep work if I wanted the engine.
I would take spark plugs out and spray wd40 to help free up the rings wait a bit then put some Marvel mystery oil in each cylinder and then crack it a bit to loosen things up a bit.
If it sounds good button it up and fire it up.
As for the th400 the caddy case is the best out there, if it didn't have a bop pattern it would be used in every Chevy, it has a better alloy mix and better finish.
Some of the internals are also better quality.
In your case the only problem is the really long output shaft, which is easily replaced.
Good luck with your purchase.
472 or 500 is great.
You'll have lots of torque with either. See what cam he had installed. Factory cams kill the engine potoential. This is long, but informative. I had it saved so I'll post it here for all:
According to the factory shop manuals, the cams look like this:
for the years '68, '69, '70
IO 18 BTDC
IC 114 ABDC
EO 71 BBDC
EC 58 ATDC
intake lift .440
exhaust lift .454
ln '71 the opening and closing numbers given make no sense. lt
must be a misprint. But the lift numbers match the '68 - '70.
'72 and '73
IO 34 BTDC
IC 100 ABDC
EO 78 BBDC
EC 58 ATDC
intake lift .490
exhaust lift .490
'74 and '75
IO 21 BTDC
IC 111 ABDC
EO 73 BBDC
EC 55 ATDC
intake lift .457
exhaust lift .473
l don't have access to a manual from '76, but l doubt it's any
different than a '75. The shop manuals make no mention of any
difference in cam specs between the 472 and the 500. Nor do they
make mention of any difference in cam specs between the
Eldorado and anything else, much though the dealers liked to
claim the Eldorado was designed for more "performance",
whatever that means. The carburetors were calibrated a little
differently, but not enough to account for that claim.
The shop manuals state that these cam timing numbers were
taken at .001 of lift, which does not compare to anything today. lt
makes the duration numbers look very long. Using a degree wheel
and a dial gauge, l measured a stock '68 cam. At .001 lift my
measurements match the shop manual specs, within production
tolerances. l also measured it at .006 and .050 of lift. Here is what
it looks like:
at .006
IO 12 BTDC
IC 78 ABDC
EO 62 BBDC
EC 20 ATDC
intake dur. 270
exhaust dur. 262
at .050
IO 17 ATDC
IC 36 ABDC
EO 34 BBDC
EC 13 ATDC
intake dur. 199
exhaust dur. 227
The exhaust lobe is about normal for a stock cam. But the intake
lobe is very strange. At the .050 level, it doesn't open until 17
AFTER TDC (l didn't mistype that). That is extremely late. lt badly
chokes the cylinder for air and fuel on the intake stroke. The 36
degree closing figure doesn't look too bad, but at .006 it's 78
degrees ABDC, which is also very late. Late opening and late
closing on an intake lobe really clobber low rpm torque. The cam
specs for all 472/500 engines reflect these same characteristics,
as do the cam specs for the 390/429 engines from '63 to '67. And
the cars these engines were in always felt sluggish and
unresponsive at low speeds under part throttle acceleration. These
stock cams are absolutely terrible. Even if you're rebuilding an
engine stone stock, use Al's MT3 cam; it will really wake up these
engines compared to the way the factory delivered them by letting
them breathe better.
Other seemingly unrelated side effects of this bad cam are that it
screws up the fuel curve in the carburetor. The fuel curve can't be
made correct under all throttle positions and rpms, no matter
what is done to the carburetor. l've tried it, and it's impossible.
Only when a well designed cam is used can the carburetor operate
the way it was designed to and provide a correct fuel curve under
all conditions. The other side effect of the bad stock cam is that it
makes the transmission shift weird, which is really only noticeable
if a shift kit has been put in it. Right before a shift when rpms are
high the power starts to feel pretty good, but after the shift the
power output drops so far that it makes the transmission feel like
it lurches and slams into gear. But put in a well designed cam and
suddenly the transmission shifts completely differently.
Transmissions from Cadillac were calibrated to shift very softly
and it nicely covers up the power output drop from one gear to
the next. But the cars are left feeling very lethargic.
Have l answered your question yet? l also tried to explain what the
stock cams are all about.
Lynn
In Reply to: Re: Stock Cams, GREAT Info for we uneducated! posted by Steve on January 28, 2004 at 14:14:20:
Those of you who have been trying to calibrate a carburetor on
top of a stock motor and haven't been able to get the results you
want, and those of you who put a shift kit in a transmission
behind a stock motor and didn't like the way it shifted, you know
what l'm talking about when l describe these strange side effects.
l have a '68 Cadillac convertible that l had for many years thought
was sluggish and unresponsive at part throttle. l'd step down on
the gas, l could hear the engine load up, and not much would
happen. l had the impression the engine couldn't breathe very well
and blamed it on the carburetor. l had been using an air/fuel ratio
gauge and a vacuum gauge to calibrate my carburetor and for two
years l chased around a bad spot in the fuel curve. lt was either
too rich somewhere or too lean somewhere else and no matter
what l did to the carburetor l couldn't get it straightened out.
Frustrated, l put the carburetor on another car on which l also had
an air/fuel ratio gauge installed and suddenly the carburetor was
fine. l put the other car's carburetor, which had been fine, on this
one, and suddenly it had the same problem. l was amazed to
realize the problem was not with the carburetor but it still took a
while to figure out what it was. l had also noticed a habit of
stepping down farther on the gas just after each upshift of the
transmission to compensate for the car feeling like it was slowing
down, but l still blamed this on the carburetor not flowing the
right amount of fuel when the air velocity through it changed.
Some 15 years ago l tried a shift kit in the transmission. l used
B&Ms kit at the stage one level. The transmission shifted so rough
and harsh that it wasn't long before l took it out.
About four years ago l finally got around to putting together a 472
with an MT10 cam l had bought from MTS about 10 years ago.
When the block was on the stand was when l measured the specs
of the stock cam and also the MTS cam. When l got it together and
in the car, l realized how much differently the engine ran, even
with an as yet unmodified carburetor and transmission. The
engine didn't feel sluggish at all; it felt like it had unlimited
energy. l could see on the air/fuel ratio gauge that the fuel curve
was operating completely differently, and it didn't take very long
to calibrate the carburetor and get what l wanted out of it. l
modified the transmission to shift even more firmly than B&Ms
stage one. lt's still comfortable and l may yet go even farther with
that. Just after the shift at the lower rpms the engine still pulls just
as hard as it did right before the shift, rather than feeling like it
slows down, and this completely changes the feel of the shift. The
difference is incredible. l realized that it was getting rid of the
stock cam that made all the difference. l don't know what the idea
was behind the intake lobe design. lt's very strange. lt doesn't
make any sense even from an emission controls standpoint. The
stock cam does nothing but cripple the motor badly.
One might think at first that a late opening and closing intake lobe
just means that the cam is ground several degrees retarded, but
that's not the case here. The point of peak valve lift is in a fairly
normal place, and it's not anywhere near the midpoint of the valve
opening and closing numbers. The opening ramp is late and fast
and the closing ramp is late and slow, which makes a lopsided
cam lobe, about like an egg that's flat on one side. lf the opening
and closing ramps had been designed correctly, the stock cam
probably wouldn't be too bad. The cams in the 390/429 motors
from '63 to '67 are the same way, which is why l asked Al in an
earlier post if he had considered making cams for that engine.
Give those poor engines some help!
Any well designed aftermarket cam from any manufacturer will fix
the problems created by the stock cam. l like Al's MT series the
best because they have appropriate valve timing figures, and they
have the most lift for a given amount of duration compared to
some others l've looked at. Even the small MT3 cam will run better
than the stock one and it will idle as smooth as glass because the
duration is short and valve overlap area is so small.
l wrote all that to say that those of you who have been driving a
'68 to '76 Cadillac (or even a '63 to '67) with a stock motor can
relate to the car feeling like this, even if you haven't realized there
was really a problem, and even if you have never tinkered with the
carburetor or the transmission. lt's easy to blame the slow feel of
the car on its weight. Those who talk about this engine having
good performance even in stock form, at the risk of being
insulting, don't know much about performance and were probably
used to the power levels of a smallblock Chevy. The only reason
the Cadillac engine had any performance at all stock is because of
its massive displacement. To those who have never driven one of
these engines in stock form, all this information is fairly worthless.
You put in an aftermarket cam and get all the benefits without
even realizing all the problems you eliminated in the process.
My suggestion is to pull the stock cam out, tie it in a knot (cartoon
style), and toss it in a creek, even if you don't like modifying
Cadillacs and want leave the rest of the car stone stock. Hey Al, if
your cam sales go up this month do l get any kickback? Just
joking. Not serious.
l also did all the other usual stuff to warm up the engine. Next
summer l want to put it on a chassis dyno and see just what it's
making. We have one in town where l live. Yes, l have been
rewarded by having a rather fast '82 Coupe. ln the stoplight wars
no one ever even inches ahead of me unless l'm not trying. The
worst that ever happens is that someone keeps up with me, but
even that is uncommon. Usually they get a good look at the
taillights of a Cadillac.
Lynn
Wow that's some good info! That will be the first thing I do if I get this car. Well I'm off to check it out and I think I will pull the plugs first and spray some wd40 into the cylinders first to be sure. Wish me luck!
well I went and fired it up and it ran smoothly, on the front of the heads they have a tube that connects to both sides and I assume its a air injector or something and on the backside of the heads there are holes that match the front with plugs in them, well the passenger side is leaking and quite a large vacuum is there. what is it? It feels almost like a freeze plug insert with a crack. I couldn't get back there to see it but I can feel it and can stop the leak with my finger till it got hot. It sounds real good and revs just fine, I didn't have my compression tester with me to test the compression but I listened with my stethoscope closely and everything sounds smooth and normal.
She wants a little more than what I want to pay for it concidering I just want the engine so my question is realistically how much can I expect to get for parting it out? It has quite a bit of rust on the body panels but it is absolutely complete, all trim pieces, hub caps, interior trim, back seat is perfect but the front is worn. Its never been wrecked so all the light bezells are good ect. I just want to know if I give her close to what she wants for it am I gonna make any of it back by parting it out?
How much does she want? And if you want a source for an engine in your area PM me. This guy has the oil pan and other goodies you may want.
I found one on CL for $350 this evening and its still in the car so I can hear it run and drive it also. Its in portland so I might run down that way this week and check it out.
