NorCoK5
Registered Member
- Joined
- Dec 24, 2016
- Posts
- 8
- Reaction score
- 7
Help!
I am building a motor, I have the bottom end done, its all stock 350 4 bolt main.
Bought a Comp Cam 270H grind for it
(480" /.480" Duration: 270°/270° RPM Range: 1800-5800)
Found some Vortec heads (062's)
some roller tip rockers 1:5
Now... I want to build these Vortec Heads and I know Comp makes the tools.. but whos done and can help me out, It looks easy enough just want some insider knowledge before I go cutting the Valve guides too short or Push rod holes too big etc... Also! What springs should I get and do I need to remove some material there too?
Thanks Yall!!
Thanks Yall!!
