BranndonC
3/4 ton status
my wife (the g/f) told me i could do what i wanted to the table
What that picture in a petersons readers rides one time?primerk5 said:this is an old pic but this is my flex with my 75
benchpress1 said:my junk![]()
thanks.. its got a 454 with howell thottle body fuel injection, th400/np205, 2 front rockwells-detroit front, welded rear, full hydraulic steering front, (future rear steer, when my budget allows)Ten_Bucks said:Nice lookin rig! Whats the specs on it(suspension, engine, trans, tcase, running gear, etc.)? Got any more pics?
benchpress1 said:thanks.. its got a 454 with howell thottle body fuel injection, th400/np205, 2 front rockwells-detroit front, welded rear, full hydraulic steering front, (future rear steer, when my budget allows)
i used 2-1/2"x2-1/2"x1/4"wall spring pad/perch, i have 6" front springs and i added a 1" zero rate to the spring pack. i also used the 1" zero rate to move the axle forward 1-1/2" that mad the biggest difference for the rockwell/oil pan clearance issues. the rear springs are stock chevy 1/2 ton springs with an add a leaf, with the same spring pad/perches on the axle with a traction lift thats 2-1/2" deep also.Ten_Bucks said:How much lift and what springs are you running to make those Rockwells work without having to lift it to the moon?
benchpress1 said:i used 2-1/2"x2-1/2"x1/4"wall spring pad/perch, i have 6" front springs and i added a 1" zero rate to the spring pack. i also used the 1" zero rate to move the axle forward 1-1/2" that mad the biggest difference for the rockwell/oil pan clearance issues. the rear springs are stock chevy 1/2 ton springs with an add a leaf, with the same spring pad/perches on the axle with a traction lift thats 2-1/2" deep also.
Ten_Bucks said:OK, thanks for the info. I know alot of people on here were wondering the same thing since Rockwells are a pretty popular discussion. Do you have any close up pics of the suspension at all?
1 of the pics didn't show up.benchpress1 said:
