Folks, I have mentioned my Cardiologist friend before. He is a truly brilliant doctor, but I have to watch him around electrical and mechanical equipment.
He also has a strange habit of asking me what is wrong with something, refusing to believe I am right, and taking it to someone else.
But, he always speaks right up if it turns out I was right and apologizes.
Don't know how this one is going to turn out.
He sent me an E-mail about his Kubota tractor.
3 cylinder 23 horse hydrostatic drive with a belly mower.
As far as I know, its all mechanical injection, no computer, nothing else.
He had some water problems a couple of years ago, but its been running fine lately.
He said that it had been running fine for about an hour, had plenty of fuel. On level ground, with almost no load on the mower, it suddenly coughed black smoke and died.
Now it turns over fine, and coughs some black smoke like one cylinder is trying to fire, but will not run.
Its not all that old, I would not expect a major mechanical breakdown like a camshaft, or anything like that.
I told him it sounded like he sucked a bird into the air filter.
I told him to check the air filter. If it was good, look closely for any fuel leakage at all.
If anything came loose between the injector pump and injectors, he should see the spray.
But if a fitting came loose on the other side of the pump, all he is going to see is a slight leak, but it would let it suck air.
I reluctantly told him he could try cracking the nut where the line goes into an injector and look for air bubbles when cranking.
I doubt I will get a chance to actually work on it, but if I do, I'll post back.
Meanwhile, if anyone has any other ideas, let me know. I'm sure I will find out what is wrong when he gets it fixed, and I'll post that here too.
