MA Old School Vortec upgrade
grendel
Boston, MA
Ramjet 350 intake, throttle body and fuel rails.
Bought this to go on a motor that ended up with a carb.
Its been sitting and could use some polish. Never been run, still has the factory plugs in it.
625.00 + the ride. Includes the throttle body, injector rails. sensors, stand alone harness and ECM ready for a tune.
It's a good upgrade for someone with an old school distributor style Vortec.
http://www.fullsizechevy.com/forum/...nce/198446-ramjet-350-intake-5-7l-vortec.html
Is this supposed to work with factory vortec injectors and ECU? I guess that's why you listed it a Vortec upgrade. Otherwise it would be a nice intake for anybody swapping from older heads to Vortec heads.
It's Vortec intake pattern. I'd suggest matching your injectors to cam and other requirements.
It does use the 97/8 Vortec distributor and ecm well.
Yeah, you said in a different post that it used 1997/1998 Vortec injectors. I was confused as to how it could do so.
Martin
Still have this? wondering what else I would need to convert my carb/distributor set up.
Haha no worries. Do you know what else I would need to convert my carb/distributor set-up??
Injectors and a computer controlled distributor, I think. Be sure the vortec intake matches the heads, may need to hog out holes. I am not a pro at this. Everything I own is LS or new LT based.
