Cajun4x4 said:use the 97' housing with teh 76' hubs for easy disck brakes if your 97 has a ff
we need pics of said axle
sweetk30 said:you cant do that. i found out the hard way. gm changed the spindles on the pop off drum style. almost 1" shorter. so nothing will swap over.![]()
Big91RustyBucket said:Also the newer one's are 11.5 not 10.5 depending on the axle.
